Adds one or more ports in a VLAN.
vlan_name | Specifies a VLAN name. |
vlan_list | Specifies a VLAN list of IDs. |
port_list | Specifies a list of ports or slots and ports. |
all | Specifies all ports. |
tagged tag | Specifies the ports should be configured as tagged. |
untagged | Specifies the ports should be configured as untagged. |
stpd_name | Specifies an STP domain name. |
dot1d | emistp | pvst-plus | Specifies the BPDU encapsulation mode for these STP ports. |
Untagged.
The VLAN must already exist before you can add (or delete) ports: use the create vlan command to create the VLAN.
If the VLAN uses 802.1Q tagging, you can specify tagged or untagged port(s). If the VLAN is untagged, the ports cannot be tagged.
Untagged ports can only be a member of a single VLAN. By default, they are members of the default VLAN (named Default). In order to add untagged ports to a different VLAN, you must first remove them from the default VLAN. You do not need to do this to add them to another VLAN as tagged ports. If you attempt to add an untagged port to a VLAN prior to removing it from the default VLAN, you see the following error message:
Error: Protocol conflict when adding untagged port 1:2. Either add this port as tagged or assign another protocol to this VLAN.
This message is not displayed if keyword all is used as port_list.The ports that you add to a VLAN and the VLAN itself cannot be explicitly assigned to different virtual routers (VRs). When multiple VRs are defined, consider the following guidelines while adding ports to a VLAN:
User-created VRs are supported only on the platforms listed for this feature in in the Switch Engine v33.1.1 Licensing Guide document. On switches that do not support user-created VRs, all VLANs are created in VR-Default and cannot be moved.Refer to the STP section in the Switch Engine v33.1.1 User Guide for more information on configuring Spanning Tree Domains.
If you use the same name across categories (for example, STPD and EAPS names), we recommend that you specify the identifying keyword as well as the actual name. If you do not use the keyword, the system may return an error message.Beginning with ExtremeXOS 11.4, the system returns the following message if the ports you are adding are already EAPS primary or EAPS secondary ports:
WARNING: Make sure Vlan1 is protected by EAPS. Adding EAPS ring ports to a VLAN could cause a loop in the network. Do you really want to add these ports? (y/n)
The following example assigns tagged ports 1:1, 1:2, 1:3, and 1:6 to a VLAN named "accounting":
configure vlan accounting add ports 1:1, 1:2, 1:3, 1:6 tagged
The tagged keyword was added in ExtremeXOS 15.4.
The vlan_list option was added in ExtremeXOS 16.1.
